GM 3inch MAF setup with pics
Old Apr 13, 2006 | 12:04 PM
Ivan_C's Avatar
Yeah keep us posted. I'll keep an eye on mine also, I'm running the GM 3.5 in beta for Tom. I just got the car back together so haven't put many miles on it.
If anything make sure Tom knows that it hasn't come back. Might help him narrow down the problem some.
Setup looks good, nice that Dejon has a premade blow through setup.
Ivan
Old Apr 13, 2006 | 12:40 PM
4TUN8's Avatar
Ivan are you running blow through as well?
Old Apr 13, 2006 | 01:15 PM
SSKILLA's Avatar
ive been keeping him updated...my code was been thrown at idle ...but no more now
Old Apr 14, 2006 | 10:49 AM
SSKILLA's Avatar
<-- been through about 3 tank fulls of fuel and still no code...cars running strong....
Old Apr 14, 2006 | 10:59 AM
RazorLab's Avatar
Interesting I would think the MAF has nothing to do with a misfire code. What's Toms take on this?
Old Apr 14, 2006 | 12:06 PM
SSKILLA's Avatar
well with my specific car it seems like it did......dont know the reason why but all i care about is that its all gone now since i put it in
Old Apr 14, 2006 | 12:10 PM
Ev0ikon's Avatar
Thumbs up
Amen.
I have been playing with the draw-thru setup. Guess I'll have to cut my shiney Upper pipe and try the blow-thru.
It's still mind-boggling that it fixed your misfire trigger.
Old Apr 14, 2006 | 12:11 PM
RazorLab's Avatar
Has part throttle driving also improved?
Old Apr 14, 2006 | 12:40 PM
SSKILLA's Avatar
the car feels 100% better all around under evrey driving condition
Old Apr 19, 2006 | 11:34 AM
SSKILLA's Avatar
:update: No Ses!!!!!!!!!!!
Old Apr 19, 2006 | 01:16 PM
SSKILLA's Avatar
HMMM started seeing a little inconsistency in my AFR today..........i tuned my car to 11.6 on 3rd gear....and now when i run through the gears "2 thru 5gear" im seeing it sometimes run 10.8 and sometimes 11.6 ....the car runs evreytime 11.6 when i run one gear but when i do runs involving me to change gears i see it sometimes run a little rich........not sure what it is .....any thoughts?
Old Apr 19, 2006 | 01:23 PM
SSKILLA's Avatar
could it be heat???....or the MAF....
Old Apr 19, 2006 | 01:33 PM
Ev0ikon's Avatar
Each gear put different loads on the engine.
You will likely see the most difference between 2nd and 4th gear.
Old Apr 19, 2006 | 01:34 PM
RazorLab's Avatar
Each gear will have different AFRs because of the load. You will also see changes in AFR when rowing through the gears because of hitting different load maps in the ecu then if you just did a pull from 2k to redline in one gear.
Old Apr 19, 2006 | 01:35 PM
SSKILLA's Avatar
well even when im going from 2nd to 3rd it will sometimes run right at 11.6 or sometimes 10.8 through the rpm range............
