AUTRONIC + HKS 264 Cams
Hi,
I am running the autronic smc and after installing the HKS 264/264 cams with cam gears settings at -2/-2, I do encounter stalling problem if I move off the car immediately with my aircon switch on. However, this stalling problem is resolved if I were to allow my car to warm up for a few minutes first before I move off. Anyone care to share his/her views on this stalling problems and does the car with HKS cams need to warm up first before moving off. Thank you.
Originally Posted by Dboey
Hi,
Hello!
Your VE has been changed with the addition of the camshafts. The ECU will need to be retuned to fix the problem you are having. If the car has more issues while cold, the warm-up enrichment table may need to be changed.
Chris Macellaro
