TPS Volts Needed
TPS Volts Needed
I never recallibrated my TPS sensor since i sent out my throttle body to be ported- and i believe my lumpy throttle response has been traced to that- I will be hooking it up today and just need to know a good volt number i should try to achieve..
I was going to go for .7 volts at idle and 4.8--5 volts at full WOT
any help is appreciated
Originally Posted by MalibuJack
my stock never touched from the factory TPS sensor currently reads .68v at idle, and 5v at 3/4 throttle.. Hope that helps..
Im really tempted to follow ur pushes to better ecu+ and might be converting soon!
