ECU + Questions
Old Jun 21, 2006 | 12:07 PM
Stew's Avatar
ECU + Questions
Have there been any developments that allow the use of ECU + with larger injectors without a underlying flash? Just curious how this system would work with a stroker motor, bigger turbo and 880cc injectors?
Old Jun 21, 2006 | 03:49 PM
burgers22's Avatar
Hi
there are options for injector scaling, have a look around the posts and see what mods people are running, plenty seem to run larger injectors.
MB
Old Jun 21, 2006 | 10:12 PM
tlcoll1's Avatar
With 880's, I'd get a baseline reflash first. Dynoflash Al will do it for under $100, so it's well worth it.
Tom
Old Jun 21, 2006 | 11:04 PM
MalibuJack's Avatar
the ECU+ compensates for injectors by rescaling the MAF signal.. so you only have a fairly small range..
You can talk to Al about getting a nice base flash, then pick up an ECUFlash cable and flash your own ECU yourself..
ECU+ and ECUFlash reflashing are the perfect combination..
Old Jun 22, 2006 | 08:40 AM
Stew's Avatar
Thanks for the info guys. I read a good deal before I posted, and seemed like guys were trying out ECU+ for bigger injectors but I was unsure of their luck.
