LMA-3 / Auxbox - RPM Connection
Old Aug 2, 2006 | 06:40 PM
cmz's Avatar
cmz
I've searched (here and on Innovate's forums), and while it sounds like I might be able to use the ECU tach signal (Pin #58)... I've seen other posts that talk about wrapping a wire around the negative of a coil/using "(Innovate's) RPM module".
The documentation states that you can either connect a tach signal or use an inductive clamp (not included w/ the LMA-3).
Anyone out there know for sure if using pin 58 works with the LMA-3?
Old Aug 2, 2006 | 07:24 PM
Jorge T's Avatar
Pin 58 works, that is how I have mine.
Old Aug 3, 2006 | 05:02 AM
cmz's Avatar
cmz
thanks
