evoscan with aem wideband? help
Old Aug 4, 2006 | 02:41 PM
sesso's Avatar
does anyone use evoscan with the aem uego? do I hook up the wideband via serial port and the usb for the data cable? and will the evoscan know athat the aem is there putting output to the laptop?
Old Aug 6, 2006 | 07:01 PM
AlwaysinBoost's Avatar
wideband reading isn't supported just yet... hopefully in the next version it will be.
Old Aug 9, 2006 | 10:45 PM
Frank Dux's Avatar
I would like to know where to hookup the wideband too...
Wideband is supported.
Here is the list of the currently supported features from the openecu page:
Data Logger Features: EvoScan v0.8
1) Supports 1996+ Mitsubishi Vehicles.
2) Log data to screen.
3) Log data to csv (Excel) file. (log format revised.)
4) XML Data Settings File.
5) DataLogging speed optimisations - up to 200 data items per second!
6) Diagnostic Trouble Code support.
- DataLog Active/Stored Fault Codes
- Retrieve EFI Fault Codes
- Clear EFI Fault Codes
7) Simultaneous WideBand serialport meter Logging Support (In beta)
- AEM Uego wideband support.
- Innovate LC-1 Wideband support.
- Innovate LM-1 Wideband support.
- Zeitronix Zt-2 Wideband support.
8) Logging SuperSpeed option
Old Aug 9, 2006 | 11:00 PM
sesso's Avatar
programmer says its not workin yet I emailed him. I guess in .9 it will be workin.
Old Aug 12, 2006 | 10:07 AM
Frank Dux's Avatar
hmmmmmm....
I will probably attempt it as soon as my wideband comes in anyway. Worst case i run AFR in hyperterminal or procomm simulateously through a serial port.
