Problems with my eevo need some help
Old Aug 18, 2006 | 08:23 PM
evoninja's Avatar
Hey i was on my way to work today and i decided to try and race a charger well needless to say i won, i think he was to scared to go as fast as i was going! anyway on my way home from work, my car was acting up, when i turned it on it was struggling to idle, and while i was drivin home my blow off valve was making funny noises, plus i dont think my car was lettin me go over sixty i was pushin on the gas but the rpm's and mph weren't going any higher! anyway anyone know whats up with my baby?
Old Aug 18, 2006 | 08:29 PM
EvoDan2004's Avatar
if you have mods what are they.
are you tunned
Old Aug 18, 2006 | 08:34 PM
7rider's Avatar
boost leak?
Old Aug 18, 2006 | 08:37 PM
idriveanevo's Avatar
maybe the bov... i was making weird sounds?
Old Aug 18, 2006 | 08:38 PM
evoninja's Avatar
dont really have any mods yet except turbo timer blow off valve, the car has 12,000 miles i bought it brand new
Old Aug 18, 2006 | 08:40 PM
evoninja's Avatar
yeah instead of the usaual sound you get from a blow off valve it sounded like it was spitting out the air, not like a soild pppsshhhhh sound
Old Aug 18, 2006 | 08:53 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
do a boost leak test and try resetting the ECU(unplug the battery negative terminal for about 10 minutes(I think it'll reset in less time but I've heard 10 minutes)). See if that does it.
I'd be surprised to find no boost lea with it acting up like that, and if there isnt a leak i hope for your sake resetting the ecu does it. sustained boostin from highway pulls can sometimes cause leaks to form from bein under pressure longer. Anyway try those 2.
Last edited by LetItBreath; Aug 18, 2006 at 08:55 PM. Reason: just thought of sumthin
Old Aug 18, 2006 | 10:37 PM
evoninja's Avatar
thanx alot letitbreath!!
Old Aug 18, 2006 | 10:42 PM
np, if you need help making a boost tester pm me. i've got a great pic of mine.
Old Aug 19, 2006 | 05:04 AM
smoothmarine187's Avatar
Veteran: Marine Corp
Check all of the lines on your blow off valve.......it sounds like something might be loose.
