Apexi Gizzmo Mivec Controller Anyone used one yet?
Old Aug 24, 2006 | 01:57 PM
GregGSC's Avatar
Well this thing just came across my desk. anyone out there used one yet? it is called a Gizzmo Mivec Fuel Controller. it is suppose to work with the evo 9 figured i would see if someone had heard of it.
From Apexi Site
The CamFC has an AFC (air/fuel controller) onboard so that fundamental fueling issues related to the addition of tuning accessories such as extractors, exhausts, adjustable cam gears, filters and mild cams can be resolved. The cam switching point is adjustable in 1 RPM increments and the switch off point is adjustable as well.
The AFC is adjustable in 500RPM increments and the switch off point is adjustable as well.
The AFC is adjustable in 500RPM increments and automatically interpolates (averages) between these points. For non-adjustable cam vehicles, the CamFC can be used to its AFC and tachometer features while the cam trigger output can be used as an RPM switch for NOS, shiftlight, high boost solenoid, etc.
CONCEPT:
Gizzmo's AFC/Cam controller is the one stop solution to solving basic fuelling issues and cam switching points on any car.
CHARACTERISTICS:
AFC RPM range: 0RPM to 9000RPM AFC RPM adjustment range: 500 RPM AFC adjustment range: +/- 40% Cam adjustment resolution: 1RPM Tachometer resolution: 1RPM Unit size: 117mmx57mmx26mm
Old Sep 10, 2006 | 11:36 PM
MBaran's Avatar
bump?
