Car problem....
Old Sep 6, 2006 | 09:07 PM
fitch's Avatar
Question Car problem....
Hope someone can help me out... In first gear the car Hesitates, then goes... It seems like it wants to go but doesn't... then all of a sudden it goes.... I'm thinkin spark plug wires... since thats the only thing i have not changed... Supporting MODS are: AMS 50 trim Turbo kit, 780cc injectors, HKS DLI2, GSC 272's, NGK BR8ES, Alky and Dynoflashed.... Car ran fine until about a couple of weeks ago... still got stock wires on... got about 44,000 miles on... The wires are a must... But anyone got any ideas....????
Old Sep 7, 2006 | 05:55 AM
Mad_SB's Avatar
have you checked your plugs... still on the stock maf?
Old Sep 8, 2006 | 02:19 AM
fitch's Avatar
yeah already checked and put in new plugs... and yes stock MAF... Thinkin really rich... maybe
Old Sep 17, 2006 | 06:05 PM
fitch's Avatar
any one that has any ideas.....????
Old Sep 17, 2006 | 08:32 PM
Ackerson's Avatar
Start checking everything mechanical first. Spark plugs, wires, boost leaks, loose wires, etc.
Old Oct 5, 2006 | 12:24 AM
fitch's Avatar
Oh, and it only does this when the engine is cold...
Old Oct 5, 2006 | 12:47 AM
xballsport's Avatar
When my car is cold my clutch is so damn sloppy, first 2 gears, its like they dont ingage or something but after a minute of driving everything is fine. On hot days i dont have this problem.
Then again your car is far more modded then mine.
Old Oct 12, 2006 | 09:01 PM
fitch's Avatar
yeah me either... the weather is affecting my car.... Now... it starts up and dies until its warmed up...
Old Oct 12, 2006 | 09:07 PM
Pure Playaer's Avatar
yea weather could b a big thing..
good or bad..
Old Oct 20, 2006 | 07:12 AM
lengvang's Avatar
i have a question ,,,,i just bought the car and i think the belts for the pump and all are too tight or too loose bc it makes alot of noise by the water pump. sometimes it revs up to 2 rpm and then back down to 1 rpm. i dont have much clue on it can any one help????
plus i put a non fowler on my o2 sensor is it suppose to stop check engine light soon??
leng
Old Oct 20, 2006 | 07:19 AM
dubbleugly01's Avatar
when the car is cold and the 02 sensor isn't up to temp, it operates in open loop. With 780's, unless dynoflash rescaled for the larger injectors, you may be running just too rich.
Or, it's MAF/intake related. I just put a 50 trim on also, with 780's and still using the stock MAF. I'm having transient issues at low rpms, and mine seem to be related to higher than normal MAF readings when they shouldn't be that high. Mine happens after it's warm, not when it's cold, just trying to point out that intakes do cause issues with stock MAF's, and it could be a source for your problem.
Old Oct 20, 2006 | 07:30 AM
Chichevache's Avatar
I'm having a problem with acceleration, I press the accelerator and it hesitates, and then it takes off. It feels like the clutch’s is slipping. I have about 2 inches of play from when the clutch engages to where it is completely is released. Is it in need of adjustment or is it a new clutch problem?
Old Oct 20, 2006 | 07:36 AM
baysick68's Avatar
if you press the accelerator - and the rpm's go up and then your car starts to move a second or to later your clutch is slipping and you need to go get a new one - i've seen stock evo clutchs go out mat 20K and less at my shop!
also if you put a non-fouler on the rear o2 and the check engine light is still on - did you put both (2) foulers in the pack in it?? or just 1?
Old Oct 22, 2006 | 07:38 AM
lengvang's Avatar
i just bought an evo and there is alot of noise coming from the acces. belts, im just wondering if its too tight or too loose and im not sure where to adjust that. or if its even the belts. sometimes the rpm goes to 2000 and back down but it doesnt sound normal. any one with answer please reply.
Old Oct 22, 2006 | 06:55 PM
pltek's Avatar
hmm
if it only does it when its cold, then let it idle until its built up some temp, its good for the engine
