Possible transition issues?
Old Oct 5, 2006 | 02:37 PM
Brian's Avatar
So I'm finally getting around to looking into the transition issues I'm having with the utec. I've always had the same issues and it seems to have gotten worse since last year. Then again I only have 1K miles since then so it may just be in my head. Then again I have stopped using the stock BC to control boost and went with a MBC.
It seems that as the motor warms up these issues become smaller, but still exist. I only have issues under minimal load, as soon as I get > ~10% throttle the issues dissapear. Additionally AFR's skyrocket as soon as this happens.
Edit:
Compression: 180 psi across the board
Spark plugs: ngk bpr7es - .025 gap < 2 miles on new plugs.
log: http://www.beergoggles.org/EVO/UTEC/logs/10032006.txt
Video: Right click save as on both, streaming from the server isn't allowed.
http://www.beergoggles.org/EVO/media...s/MOV01461.MPG
Can hear what I'm talking about at 15 seconds in.
http://www.beergoggles.org/EVO/media...s/MOV01462.MPG
Can hear what i'm talking about immediately in the video & see it with the AFRs spiking to lean at 14 seconds in and then again at the end.
Old Oct 5, 2006 | 07:39 PM
Brian's Avatar
video added, thanks to those that can help.
Old Oct 6, 2006 | 11:24 AM
BJai02's Avatar
I am sure it has to do with transition. Try to make your 10% load site to "ECU" for now and see if it helps.
One mor ething to check. If you have the logger, try to see if your fuel trim is in a reasonable range... +/-10
Old Oct 15, 2006 | 11:55 AM
Brian's Avatar
Bjai02: thanks for your response.
So I bought evoscan and did some logging & have changed my injector scaling a bit on my 780's. I'm down to 590 right now. I also ecu'd out my timing map to get that out of the way. So now i'm back to where I used to be, if the car is warm it doesn't do it but once in a great while but while cold it's still an issue.
WOT is solid though, or was before I started dinking with the injectors.
Check out some of my evoscan logs:
http://www.beergoggles.org/EVO/ECU/e...5_13.09.08.csv
http://www.beergoggles.org/EVO/ECU/e...5_13.09.49.csv
http://www.beergoggles.org/EVO/ECU/e...5_13.10.45.csv
http://www.beergoggles.org/EVO/ECU/e...5_13.11.09.csv
http://www.beergoggles.org/EVO/ECU/e...5_13.11.52.csv
I tried to end each log just after my issue occurred, kind of unclear really on how to read the ST LT trims though.
