Are the oem spark plugs okay for 23-24psi?
Old Nov 8, 2006 | 01:28 PM
tsherriff's Avatar
Question Are the oem spark plugs okay for 23-24psi?
I own a 2006 EVO IX MR and would like to know if the oem spark plugs are okay for 23-24psi? Do I need to upgrade to the NGK Iriduims? if so, what should the gap setting be?
Old Nov 8, 2006 | 03:07 PM
Gusl's Avatar
Plugs
You wont have any issues. Check the gap. You may want to go smaller maybe 26
Old Nov 8, 2006 | 03:22 PM
tsherriff's Avatar
Thank you. I'm not sure what the stock gap setting is, I'll regap them at 26 then. Are the OEM plugs NGK double platnum?
Old Nov 13, 2006 | 01:35 AM
snake's Avatar
apparently my mechanic told me its iridium in evo ix.
Old Nov 13, 2006 | 03:56 AM
evo72man's Avatar
Someone told me run cooler plugs for higher psi.
