Uego AFR logging to have rpm based graphs
Hey guys, I just picked up my 03 EVO and it already had an AEM Uego installed with the guage. Well, I dont know about you guys but I think that it is about the most useless piece of electronics there is without having the ability to log the AFR aginst RPM's.
Ive searched and found the common method of logging is through the use of an EMS, which I will not be getting any time soon. So my main question is, if I wanted to log my AFRs against an RPM signal, how would I go about doing so? Evoscan? Can it be done through Hyperlink? Do I need an AEM EMS? Im used to an Innovative wideband so if this is a PITA I may have a Uego for sale!
So if I have evoscan version .9, does anyone know how to set up the uego to be logged through it? Do I need the tactrix cable hooked up to my OBDII port and the UEGO coming in through a serial port. If so, how do I connect the 0-5v analog signal into the serial port connector.
