air/fuel?
Old Dec 20, 2006 | 07:39 AM
fitbikedominick's Avatar
air/fuel?
Ive done some searching and i still cant find a definate answer as to what is a safe Air/Fuel for 93 octane. I have a BR stage one and their flash, my wideband goes as low as 9.9-10.1 is this good?
Old Dec 20, 2006 | 07:47 AM
bump so im not parinoid drivign to work in 10 minutes
Old Dec 20, 2006 | 07:59 AM
9sec9's Avatar
That's too rich, but it's definitely safe to drive. If air/fuel gets 12.0 - 12.9 then start being concerned for the 'safety'. You need to have it tuned, however. What mods have you done to cause it to be so rich? Is it also rich while your in 'boost', if so, what is the A/F through out the RPM range (boost range)? You would normally be looking for an 11.5 or so, give or take .2 either way.
Old Dec 20, 2006 | 12:44 PM
My mods are 3 inch turbo back, cone filter mas adapter, mbc set at 20 psi, all tuned b buschur racing. It dips down to 10.2-10.0 when i let off the throttle after being at full boost. regular driving its fine.
Old Dec 20, 2006 | 12:45 PM
krafty's Avatar
11.7
Old Dec 20, 2006 | 12:48 PM
should i turn the boost down some to make it so it dosnt go below 11.7
Old Dec 20, 2006 | 12:51 PM
EvoAnthony's Avatar
No! The higher the # the leaner....the lower the # the richer....you my friend are too rich. If anything don't mess with the boost and get a retune.
Old Dec 20, 2006 | 12:55 PM
Nez136's Avatar
^+1
Old Dec 20, 2006 | 12:59 PM
I got tuned by Buschur for the stage one which they have most liklydone 100 times. Could my wide band be off? Im gunna go for a drive real quik and come back so i can keep track of what exactally is happeing.
Old Dec 20, 2006 | 01:24 PM
Gsr Mann's Avatar
Maybe your sensor is going bad, you should feel a reduction in performance running that rich. Also check your plugs for black deposits. Normal burning plugs tend to be more brown than black.
Old Dec 20, 2006 | 01:30 PM
all right i went and filled it up. Came back 15.8-16.2 idle 10.7-11.2 full boost 21psi peak holding 19-20 psi (boost contoller is awsome ) dips down to 10.2-10.4 for a split second when you go wot from 3200 rpms.
I run 93 octane. Wide band is the new AEM UGEO installed a month ago.
Old Dec 20, 2006 | 01:39 PM
bump for new information
Old Dec 20, 2006 | 05:32 PM
bump
Old Dec 21, 2006 | 07:07 AM
krafty's Avatar
idle should average 14.7
