What should I do for a tune?
Old Dec 20, 2006 | 12:05 PM
ultimatesteve's Avatar
I just purchased a 03 evo with hks ti/carbon TBE, and a p2 flash. I just put it on the dyno and its running a bit lean and not making very good power. They said it needs tuning but I was hoping to hold off till cobb released the accessport. What should I do till then?
Old Dec 20, 2006 | 01:37 PM
xtremeIX's Avatar
What reading is telling you the car is running lean and what is the engine putting out in the power department that makes you believe it's not producing good power? Can you post the dyno run? I don't believe you're going to be able to tune the car even if cobb does release the access port. When you have the p2 flash I believe WORKS are the only people able to tune your car.
Old Dec 20, 2006 | 03:00 PM
Peak
awhp 216.7@6250
tq=231.1@3750
max boost 21ps
the a/f is running 11.6@5200rpm then tapers up to 12.2@6300
in first gear which I believe is giving me some poping and a slight hesitation under hard acceleration
Old Dec 20, 2006 | 07:36 PM
xtremeIX's Avatar
Something is definitely wrong in the performance department of your Evo. I would call WORKS and talk to them about the problem; it's much easier for you and them. How many miles is on your Evo?
Old Dec 21, 2006 | 09:14 AM
It has 32,000 on it and has had every service at or before it was due and doesnt have a single sign of any other drivability problems. I called works and they helped me with a few things, but I think I am just going back to stock and goint to get the cobb accessport.
Old Dec 21, 2006 | 10:31 PM
NiteRider's Avatar
not to say that COBB isn't a good company but why would you want to go with COBB rather than get your P2 reflashed?
Old Dec 22, 2006 | 03:35 AM
Smoothgangsta's Avatar
Exactly.
WORKS is to the Evo what COBB is to the Subaru as far as tuning.
Nothing against COBB because I will be going with them shortly for my 2007 STi in 1st quarter of 2007, but WORKS has been tuning the Evo for longer than anyone for the Evo. I had NO REGRETS on having the P2r flash on my 2005 Evo and the WORKS TR-340 kit on it.
The only reason I would say go with Cobb is if you would like to have switchable maps for valet, economy, 93 Octane, or a race map for the track.
With WORKS there is no option to do that unless you want to have them flash the ECU for a 93 tune, then dump the ROM via ECUFlash, send it off to have it flashed for 100 Octane and dump that ROM via ECUFlash, then you could switch on the fly with a laptop via ECUFlash, but that's alot of hassle.
If you want an on the fly switchable tuning solution go COBB, otherwise if one good 91 or 93 Octane tune is what you want then go WORKS.
Old Dec 22, 2006 | 09:34 AM
A huge reason that I am going with the cobb AP is cause I live just around the corner from a reputable tuning shop that can make me custom maps for a very reasonable price. Also with the AP I can make several maps and easily switch them in car. For instance I can have a race gas/pump gas/stock/valet friends and family ect ect.
Old Dec 24, 2006 | 12:11 AM
EvOcHaRgeR's Avatar
You can acutally pull your p2 flash map using ecuflash.
Old Jan 1, 2007 | 07:37 AM
USAF_STi's Avatar
Would this shop happen to be Fine line imports?
Old Jan 1, 2007 | 04:40 PM
yep
Old Jan 1, 2007 | 04:47 PM
evo-mutsumiko's Avatar
thats what i was fixing to say. get a tactrix cable for 90 and download openecu for free. also you can register for evoscan which i think is 25 and tune yourself. save you a couple of hundred!!!
Old Jan 1, 2007 | 05:19 PM
But can you get a custom tune with it? Also can you have several stored maps for race gas and stuff?
Old Jan 1, 2007 | 05:26 PM
you can pretty much do what ever you want. DD maps, race maps, valet maps, high oct maps, etc.
i have about 15 different maps on my laptop. most of them i just tweak here and there. also, once you have the program you can download the map you have on your car and send it to Dynoflash and get a Eflash to start you off for 40 bucks
Old Jan 1, 2007 | 05:28 PM
actually...i don't know how much there are now, but when i did it it was. i started with his map and sortof tweaked maps from there. then when i got used to it and understood it i put my car back to stock and made some of my own
