Map Sensor Kit
Map Sensor Kit
Where can i get the map sensor kit for the Djetro, and is there anyone that has the rough base #?
My wife was messing around with the system and deleted all the base numbers and stuff. Lucky i had the stock ECU still.
Will the Djetro be good a good start for the GT35 and all the extra mods?
www.nengun.com has it
Cool, thanks bro. Do you know if anyone can get me the default numbers, or some rough number for my 03 VIII.
Just gona need a rough tune so i can get it to the shop. Will be running a GT35, 272in/ex, HKS cam gears,1000cc injectors.
As suggested, a reset to factory default will give you back pfc in original version, as regards your 1000 cc injectors, in the dedicated setting boxes, if you have a datalogit or similar, start with 56,0 and 0,28/0,30 lag for both 4 injectors, it should work quite well. As regards sensors, the standard map sensor that comes with the Apexi kit is good for about 1.8 bar ( 26/27 psi ), for getting the best from your gt35r you will need an upgraded sensor, like a 3.5 or 5 bar absolute AEM sensor, or, if your boost goal is not over 36/37 psi, for having nothing to modify in the electrical cables, you could use a map sensor that comes as oem with avcrs, same connectors and it works really well. Obviously, after having changed the sensor, you will have to set it up by rescaling.
Hope it will help, excuse me for my english, i'm doing my best of italian guy....
Well all the numbers in the FC got deleted, so i am not really sure where to even start. im currently in Japan so i wont be able to apply this until i get back to HI. I plan on running about 23-30psi and kicking it up on the weekends with race gas. But That info is good, now i know that the Aem 3-5bar will work. Thanks Again
