Innovative wideband
Old Feb 6, 2007 | 09:00 AM
vroomevo's Avatar
Innovative wideband
Hello,
i just installed LC-1 wideband with XD16 gauge.
i am trying to log with ECU+.
i see LM-1, AEM, PLX etc on the WB selection, but not LC-1.
how can I use EUC+ for loggin AF using LC-1?
thanks.
Old Feb 6, 2007 | 11:48 AM
MalibuJack's Avatar
Yes! It uses the analog 5v output on your LC-1, I think the calibration is the same as the LM-1
If not, you can use the configuration utility for the LC1 to configure the wideband's output voltage to match one of the available options.
For example, I have the 5v output of my TurboXS Tuner Pro, calibrated to the same value as the PLX wideband, and it logs perfectly in ECU+
Old Feb 6, 2007 | 04:16 PM
tlcoll1's Avatar
LC-1 will be officially in the next release. For now, configure it to be like the LM-1 or PLX.
Tom
Old Feb 6, 2007 | 08:41 PM
vroomevo's Avatar
thanks for the replies.
when i set it to PLX, values on gauge and ECU+ are very close to each other. i guess i will set it to PLX for now.
So, Tom...when will we be able to get new update?? with MUT logger and etc...
can't wait...
