s-afc??? help
Old Feb 12, 2007 | 05:31 PM
evoboy8990's Avatar
s-afc??? help
i sold my s-afc and i need help on how to remove the s-afc. what are the step to removing the s-afc? i wont be needin it anymore since i got a jestr reflash. anyways please help me out, i really need it.
thanks
Old Feb 12, 2007 | 06:08 PM
Happy Hazard's Avatar
I'm taking it you didn't install it yourself?
Old Feb 12, 2007 | 06:34 PM
evoboy8990's Avatar
no i bought the car with the s-afc already on it
Old Feb 12, 2007 | 07:46 PM
whitey4d's Avatar
All of the wires are just "tapped" except your airflowo signal wire that is actually cut. You would have to remove glove comparment to reach acces to the wires goin into the ECM. basically strip off all the connectors that have the wires just tapped. Then the two that actually go into the AFC you have to disconnect and re connect to each other or you wont have and airflow signal to your ECM. Any ??s go to WWW.VFAQ.COM then look under 2G Electrical. It has all the answers. Bythe way EVO 8s and 2Gs have the same wiring connects. 9s are different tho.
