need more help with the mas
Old Feb 14, 2007 | 08:53 PM
DizeLLx's Avatar
im running the ecu plus with the gm 3 mas sensor now im not sure which wires to run it from the ecu plus and to which i plug them into and whihc ones i cut out of the oem mas plug if someone can tell me which colors theres 3 wires i need to hook up voltage signal n ground but not sure to where exactly thnx for ne help
