works p2e datalog
Old Feb 17, 2007 | 07:01 PM
FastAzzEvo's Avatar
works p2e datalog
I wanted to datalog my works flash before I add a bunch of new parts and get a custom tune. I wanted to post this because I am very happy with the tune for a mail in tune.
This is a p2e flash with just a tbe
The portion of the log I am noting is a 4th gear pull from which I wrote info on from 4000-7000rpm
Boost does hold pretty good.
The pic tells the rest.
Thanks works for a great product.
The Text on the data log pic is where the vertical line begins, in between that and the end of the 4th gear run you can see pretty much the afr in the low 11s to 11.9 or so at 7000rpm, then the boost staying at 20psi the very last been of the run where it drops to only 18.80psi
Also, I used my tactrix cable, and logged knock, not a single knock count.
Old Feb 23, 2007 | 03:45 PM
Jamie@WORKS's Avatar
Thanks for sharing
