Stock Evo AFR
Old Mar 25, 2007 | 04:03 AM
4wheel_motion's Avatar
Stock Evo AFR
2005 Evo
3" TBE
K&N drop in filter
Greddy Profec-B
19-20psi (@ redline)
ZT2 wideband
Do these AFRs look right for an untuned 05 evo? I was under the impression Evo's ran much richer than this stock? I mean, considering most of you guys tune for the 11-11.5 range, my cars a bit on the lean side . . . stock. At idle the WB reads 14.7-14.8 for calibrations sake, and its located right under the firewall.
I'll post up the evoscan data soon.
In the 5000 to 7500RPM range AFRs where solid 11.8-11.9, and EGT held 1040-1050 degrees F
knock was in the 0-1 range except at 6800Rpm where it got a random 10count and held 9-8count to redline.
Am I running too much boost on the stock tune or what? I'll post up the evoscan data soon.
