AFR variations due to temperature?
Old Mar 25, 2007 | 11:06 PM
SlowCar's Avatar
today, while logging my AFR on a 4th gear pul, my AFR has gone 0.5 richer compared to 2 weeks ago whe the temperature was much cooler/colder...does temperature have such a drastic effect on AFR?
more about the car:
-stock evo ix with 1000cc/min methanol injection
-27psig peak tapering to 21psig at redline
-flow rate of methanol was the same as 2 weeks ago, logged thru a aquamist dds3 failsafe.
Old Mar 25, 2007 | 11:21 PM
fusionchicken's Avatar
i always have this question as well, bump for an answer
Old Mar 25, 2007 | 11:23 PM
Hic's Avatar
Hic
temp compensation should be better
Old Mar 26, 2007 | 07:29 AM
jfitzpat's Avatar
Remember, your ECU pretty much guesses at AFR WOT. Closed loop, it should stay very close to 14.7 because it has a narrow band sensor to help it find that point.
But open loop it takes a 'best guess', using such factors like air flow and inlet temp. So, it if you have moded a car to effect VE, you need to adjust the 'guess' tables accordingly.
-jjf
Old Mar 26, 2007 | 10:19 AM
SlowCar's Avatar
-jjf
Thank you!
