Can the dealer tell?
Just checking to see if I reprogram the ecu and then put the stock program back in can the dealer can tell something was done? I had a SCT programmer with my last vehicle and when I would bring it in I would just pull the old tune out and put in my factory program and they couldn't tell. As far as what they would see, it would look like I disconnected the batteries and reconnected them.
Thanks
Thanks
I think the stealership can tell that something was changed in the ECU, however I don't believe that they can tell what it was. I may be wrong here though.
Also, I don't believe that they really even check this sort of thing unless there is a major problem with the car and they are specifically looking at the ECU as the problem.
I found out the 9 ecu is just like my last vehicle. Pull the stock tune out and replace it with a modified one and you can bring it back to stock like nothing happened.
