serial to usb help
serial to usb help
hey guys i installed my wideband lc1 and connected the red wire to 12v and the white wire and blue wire to ground and hooked up the serial>usb cable to the serial cable that comes with the lc1 but it wont connect in either mitsulogger or in logworks. what am i doing wrong?
ps. yes i did calibrate the sensor.
- shane
- shane
. its put into debug mode when you open LM manager and you gotta reset it (recycle the ing.) and then open log works
