What has to be checked to log load?
Old May 12, 2007 | 12:30 PM
Chemwarrior's Avatar
I was doing some logs and when I got back to the house to read what I did I noticed that load had all zeroes. This is what I had checked: timing, RPM, KnockADC, AFR, knock, load, throttle, knocksum, TPS, and O2sensor. What has to be checked on MitsuLogger to log load? Thanks.
Old May 12, 2007 | 12:37 PM
burgers22's Avatar
Hi, to log real load, you need to mod your ROM, check the ECUflash forum for 2 byte load thread, you should already be able to get a load calc from Mitsilogger.
MB
