Mitsulogger --> Excel
Old May 18, 2007 | 07:45 AM
PorkRoll's Avatar
I just started to log, and everything seems to be working fine. However i dont know how to copy the logged data into excel? Any help would be appriciated.
Old May 18, 2007 | 11:58 AM
PorkRoll's Avatar
bump for answer
Old May 19, 2007 | 04:21 AM
Mellon Racing's Avatar
I use Evoscan primarily and haven't used Mitsulogger in a long time but it should be making a .csv (comma separated values) file on your hard drive. Simply double click on the file and it'll open up in excel.
Old May 19, 2007 | 04:35 AM
wrcwannabe's Avatar
This is correct. You will need to find the directory where Mitsulogger is storing things. I have 2 other suggestions. Make a shortcut on the desktop to the directory. And then when you open Excel set the view to 50%, sort on knocksum in descending fashion to see the highest knock right away. then use the back arrow to unsort to the original view . You can hide the columns of no interest to you to make less data on screen to help out visually.
Also you dont have to actually log all data in Mitsulogger, just uncheck the unwanted items before starting the log.
Old May 19, 2007 | 05:47 AM
nothere's Avatar
before you start to log open the grayed window that places the logged file somewhere. put it where you will find it.
it automatically ends up in excel format for me, I just have to remember to place the file before I log.
