Avcr Help
Old Jun 26, 2007 | 01:41 PM
I Kill Suckers's Avatar
Avcr Help
What do u have your boost and duty set at?
Old Jun 27, 2007 | 05:36 AM
Bosshog's Avatar
You set your boost to whatever you want to run at various rpm (you need to map the car for that boost). Duty cycles, I would start with around 50-60% in lower gears and increase to 80-85% by higher rpms
Old Jul 30, 2007 | 09:09 AM
bustin's Avatar
you need to set your target boost.
go slow...dont increase your duty by much each time...i use 2% increases.
i could list my settings, but the duty will be different on everycar....
if you need some help or whatever, PM me.
