can 100 octance change AFR?
Old Jun 28, 2007 | 01:16 PM
vroomevo's Avatar
Hello.
my AFR used to be in 11.4-6's in upper RPM. recently, i put 100 octane and at the same time, disabled lean spool up.
now my AFR drops down to mid 10's in upper rpm.
can 100octance change AFR? i am suspecting it's all b/c lean spool up disable but just wondering if 100octance can also cange AFR.
thanks.
Old Jun 28, 2007 | 02:46 PM
recompile's Avatar
Disabling lean spool will do it.
Old Jun 28, 2007 | 06:14 PM
Mellon Racing's Avatar
higher octane fuel is going to burn more slowly which can make you rich too
Old Jun 29, 2007 | 10:09 AM
vroomevo's Avatar
hmm...so i shouldn't modify my fuel map based on high octane now. i will be using 91 for the most of the time. only pumped 100 octane for boost controll set up, sometimes i get overboost/knock.
Old Jun 29, 2007 | 10:15 AM
correct, if you run 100 octane fuel and lean out the AFR to say 12.0:1 and then later fill up with 91 octane and don't add fuel, you're probably going to burn a hole in the piston
Old Jul 9, 2007 | 05:25 PM
Flyin EVO 2's Avatar
100 octane fuel is also heavier vs. 93 octane, and C16 is heavier than 100 octane. Until you get into alcohol based fuels, usualy the rule of thumb is the higher the octane, more additives, the more it will weigh. If your out of injector on 93, you might have enough on 100. Any time you change fuel types you should re-tune a/f ratios.
Old Jul 10, 2007 | 05:10 AM
TouringBubble's Avatar
I was under the impression that octane value didn't affect the fuel burn at all, only the resistance to knock. I don't have any real knowledge of this on my own, I've only read it in a few articles.
This is one place I've seen it ... Wikipedia's "Octane Rating" entry.
Originally Posted by Wikipedia
Octane rating has no direct impact on the deflagration (burn) of the air/fuel mixture in the combustion chamber. Other properties of gasoline and engine design account for the manner at which deflagration takes place. In other words, the flame speed of a normally ignited mixture is not directly connected to octane rating. Deflagration is the type of combustion that constitues the normal burn. Detonation is a different type of combustion and this is to be avoided in spark ignited gasoline engines. Octane rating is a measure of detonation resistance, not deflagration characteristics.
I guess this means that 100 octane could have other properties that will change the burn that aren't directly related to its octane rating.
Old Jul 10, 2007 | 06:00 AM
here's a for instance... I was tuned for pump gas ~ 11.5:1 on my stealth... I put in 5 gallons of c16 when I got to the track and the WB02 sensor died and I ran 125mph traps at 25psi pig rich.
I got home, installed a fresh WB02 sensor and found out that the C16 had me at 10.5:1. I ran the C16 out and filled up with pump gas again, the AFR went back to 11.5:1 and I ran 125mph traps again but this time with less octane and 22psi since I was a the proper AFR for the octane.
Old Jul 10, 2007 | 11:27 AM
C16 is leaded though. I assume that leaded fuel will burn differently than unleaded. Is the 100 in question leaded?
Old Jul 11, 2007 | 03:13 PM
alpha's Avatar
Was the ignition timing untouched when the C16 went in? 125 is quick for a Stealth
Old Jul 11, 2007 | 03:34 PM
Planet Evo's Avatar
The high octane fuel vs. pump fuel debate has been going on for ages it seems.
They "burn" at the same rate. Regardless of the octane level.
The difference is how it reacts with heat and the way in which the flame front is propagated.
Lower octane fuel such as (everyones) **** 93 octane will seem to have a tendency to burn thru because of its volatility rate vs. the ignition advance used. You are actually just measuring, thru the 02 sensor, the portion that was burned. Technically you are running MUCH richer on the lower octane fuel than what the wideband is reporting. You don't realize it until you are dealing with an octane level that can take the heat and burn completely thru the cycle. One of the reasons you will run into rich misfires when running race fuel with insufficient ignition advance.
So to answer the above question.. you NEED to check AFR's and make adjustments. But its not the burn rate that effects anything.
Old Jul 11, 2007 | 03:56 PM
I monitored knock and ramped the timing up..never saw any knock but I went so far with the timing that the car actually dropped to 122-123mph traps so I pulled it back down a litte bit and got back to 125's
thanks, it should go mid 130's at full tilt (~ 35psi max) when I get back out there.
Old Jul 15, 2007 | 06:26 AM
tephra's Avatar
Hey Chris,
So you busted your O2 sensor because of the leaded C16 right? - not because you were running rich!
Old Jul 15, 2007 | 06:43 AM
leaning it out to 12.0 to 12.2 on C16 didn't extend the life significantly... leaded fuels kill WB02's
Old Jul 26, 2007 | 06:25 AM
DeiPro's Avatar
This is correct. Octane rating does not, in itself change the AFR. It is the SG and other components in the Higher octane fuels that change it. What I tell customers is if the car is optimized for a fuel, any change, higher octane fuel included, should be recalibrated for best performance.
