EvoScan question
Old Sep 16, 2007 | 02:37 PM
MikeIsBoosted's Avatar
EvoScan question
Hey guys, I have an OBD2 interface connector that I used to use in combination with a palm pilot to log data on my old 98 GSX. I broke the palm, so I can't use it anymore. So, I still have the interface module, and a Keyspan serial to USB connector. My question is if I can plug the interface module in and use that instead of buying a Tactrix cable so I can log with EvoScan?
If you don't know what the interface looks like, here is a picture - http://www.dsmloggers.com/interface.jpg
Thanks guys!
Old Sep 17, 2007 | 12:33 PM
Bump.
I just ordered a 9 pin female to female serial connector since I need that to hook the interface and usb cable converter together, so I'll know in a few days.
Old Sep 21, 2007 | 09:12 AM
Well, I tried using the above mentioned setup with a generic obd2 scanner program, and with MitsuLogger - neither worked. What is so special about the tactrix cable?
Old Aug 24, 2008 | 03:13 PM
TwistedEvo8's Avatar
Bump! Sorry to bring up old thread but I also have the same and was wondering if you can use it to log?
