New to PFC
Old Sep 27, 2007 | 02:30 AM
EvoVIII808's Avatar
New to PFC
Just installed me PFC D-Jet, and does not start. Starts with Stock ECU.
I searched here, found some threads about not starting. But everyone i read seems to be a bit differnt. I hook in the commander and the IGN, FPR sensors were colored in. I guess meaning not getting signal. My question is IF i hook it up right. For air temp ( taped into manifold) wired RED- RED/BLUE on stock, and Brown - Black wire.
Another thing is i dont understand the swaping of the wires. Does anyone have a pic of this? Do i Tap and connect pin 8 and 22 together? or cut 8 and run it to 22 or vice versa?
Old Sep 27, 2007 | 05:48 AM
94AWDcoupe's Avatar
Which unit do you have? If you bought one for the 8 there will be no wire swapping. If you need to swap 8 and 22 you have to cut them. I put male and female connectors on mine so I can swap back to stock ecu quickly.
Old Sep 27, 2007 | 08:27 AM
EvoVIII808's Avatar
i think i have the ecu for the evo7, although i bought it used from someone on here, and he was running it on his 8 with no problem. maybe thats what i need to do since it not getting any fuel.
