Reflashing a stcok ECU
I am thinking to reflash my original ECU too.
Is it possible to save my orginal tuning from that ECU to somewhere(Perhaps paper or disk or CD) that I can use it back again once I am ready to go original settings again?
If not, I may go and buy another ECU for a spare just to reflesh purpose. So that my original stays at original settings.
Is it true that by setting/reflesh ECU, you can gain 100HP++?
You just hook up the laptop to the ECU with your tactrix and download it using EcuFlash.
Simple as that. You can upload the stock ROM whenever you choose
I have flashed mine over 200 times and no problems yet. Some professional tuners have stated 1000 times as the max. Now I am sure there is someone who has run into problems at say 300 flashes and some one who has over say 1200 flashes and still no problems.
SunKren, check out the video on my website... it'll explain how to download the stock ROM and save it and upload a new rom. www.mellontuning.com
thats like saying you can only go to 20 web sites on the computer then your stuck with the 20th one hahaha...
Quick simple answer....
You are misinformed..
There is a theoretical limit to how many times the same area of memory can be rewritten by the manufacturer of the memory chip on the ECU.
So far nobody has reached that limit, and there have been some members with thousands of reflashes.
