I've done some research but want some others opinions as to why they prefer either of the 2 above mentioned. Innovate LC1 and the AEM Uego. thnx
innovate lc-1 with the xd-16 gauge.....the aem one just looks and feels cheap....
i recomended the lc-1 to several evo owners in the area adn they are all happy......one even switched from the aem one.
LC-1 and whatever gauge you want. The LC-1 has the digital output as well as 2 analog outs so you have some options gauge-wise. Hurry up and get something so you can be faster than me again ...
where did you guys ground your LC1? I cant seem to get consistant readings, but i think its because of my wiring. Some days its fine, some days its not.
BUDLoNG
BUDLoNG
Mine is grounded in the same place I grounded my TT and shift light ... some random stud/nut behind the glovebox area. I grounded the LED and calibration switch under the console near the e-brake.
i put a screw into the chassis with the ground wire... works like a charm
i have mine grounded behind the stereo... Seems that place should work fine, if your locations are working.
weird
weird
