IX Log
Old Nov 4, 2007 | 05:43 PM
bank277's Avatar
IX Log
Can someone check out this first to third gear log. I don't really know what i'm looking at. Just wanted to make sure i'm not having any problems. Mods cosworth 272cams, 780 injectors, head studs, hallman mbc about 21-22psi, walbro 255, drop in air filter, TBE, runing test pipe, LICP, and 93oct tune. Thanks
File Type: txt
Old Nov 4, 2007 | 05:46 PM
bigric09's Avatar
let me dig more into it, but you are knocking like hell, your fuel trims suck just after first glance...
edit, when i opened it up with notepad the columns were off...
in excel, your fuel trims are still off, you arent hitting the load cells you should be....
you definitely need a better tune
Old Nov 4, 2007 | 05:50 PM
kreionic's Avatar
It doesnt look like the columns are lining up correctly. What program are you using to log? Can you post a .csv?
Old Nov 4, 2007 | 05:53 PM
bank277's Avatar
I thought something didn't feel right. Thanks for the help
bigric09's Avatar
charlie,
i opened it with excel the 2nd time... it seemed to open up fine then
Old Nov 4, 2007 | 05:54 PM
bigric09's Avatar
feel free to email me your rom and i will look at it for ya
jsnrchtr@aol.com
jason
Kuslowski's Avatar
*edit* ^ yep excel...
Old Nov 4, 2007 | 05:55 PM
kreionic's Avatar
Originally Posted by bigric09
charlie,
Good call man It works with excel. Ok so i was right about them not lining up in the .txt.
Old Nov 4, 2007 | 05:57 PM
bigric09's Avatar
yes... at first i thought his car was doomed, then after i used excel, i knew it wasnt doomed, just slow lol
bank277's Avatar
I'll try to figure out how to. I'm not so great with computers.
Old Nov 4, 2007 | 05:59 PM
kreionic's Avatar
Its cool man it opens correctly in excel. Your knock is very minimal. Bigric09 offered he knows he stuff he can help you out some
Old Nov 4, 2007 | 06:05 PM
bank277's Avatar
I'm not sure were my boost is at. Sometimes it will read 19 and other times 22 or 23. So i've been keeping it on the low side to be safe. I may need to get a better boost gauge to set my boost accuratly.
Old Nov 4, 2007 | 06:06 PM
kreionic's Avatar
Jason just keep in mind if you help the wonderful 91 octane
Old Nov 4, 2007 | 06:22 PM
bigric09's Avatar
i know .... thanks for the reminder charlie.... how is the freak doing ?
your boost is doing that more than likely due to the different gears, unless you are experiencing this during different times of the day in which case its weather related.
Old Nov 4, 2007 | 06:23 PM
bank277's Avatar
I neen to update my profile I live in Maine now. 93 octane.
