Easy ECU question...
Old Nov 29, 2007 | 06:40 PM
bryan428's Avatar
So I found the diagram for my car to connect the VSS wire... However, were can I locate this harness?
http://www.ttp-engineering.com/TTP.IX.ecu.pdf
Old Nov 29, 2007 | 08:00 PM
TouringBubble's Avatar
That is the main ECU harness and it's just under the left side of the glove box. Remove the glove box and slide out the plastic cover on the underside of the dash to access the 3 plugs in the diagram.
