ECU locked need help
Old Jan 8, 2008 | 05:53 PM
TangoASI's Avatar
Hey guys I kinda need some help. I just came back from Street Tuned Motorsports in Rochester, NY for some installs and a road tune. Well when Em at STM tried to flash my ECU it wasnt reading it, he tried many times and called AMS for some help and still couldnt get my ECU to read any maps, he said my ECU was locked, if anyone could help me figure this out so I can finally get my car tuned it would be appreciated.
Old Jan 8, 2008 | 06:11 PM
cfdfireman1's Avatar
Mitsubishi ECU Unlocker 1.1 for ECUFlash
Can be found here
http://www.aktivematrix.com/forum/
Old Jan 8, 2008 | 06:20 PM
TangoASI's Avatar
he said he downloaded the latest one (unlocker) and it still didnt work and said maybe the previous owner had an ecutek or something I dont know quite remember
Old Jan 8, 2008 | 06:21 PM
90GSX-03EVO's Avatar
Bah, I'm way off here. Nevermind.
Old Jan 8, 2008 | 06:24 PM
TangoASI's Avatar
basically he couldnt get into my ecu, he went on the internet and dl the latest ecuflash and he still couldnt unlock my ecu. He said your ecu isnt reading anything and its locked and then he called AMS and went back into my car and looked under the dash and then reset my ecu and it still wouldnt accept any maps
Old Jan 8, 2008 | 07:15 PM
Evoryder's Avatar
not sure if this will work for you...but there have been a few cases where if the battery is low the ecu will not allow changes and will give you errors. Just a suggestion, go to your local autoparts and have your battery charged or go for a spirited drive then try again.
If that fails, you may need to go to the dealer.
Old Jan 8, 2008 | 07:17 PM
bigric09's Avatar
the unlocker in my experience never lets me unlock the ecu... it only allows me to grab the immobilizer code and resets the init code to 0001 so the ecu is flashable again...
you will need a map to load your immobilizer on and start things rolling again
Old Jan 8, 2008 | 07:21 PM
TangoASI's Avatar
well I drove for 3 hours to STM so I dont think it was the battery unless it somehow was being drained while they were install my boost gauge aem uego gauge buschur licp or hallman boost controller and bigric I cant personally say Em at STM tried your method but basically he told me I would need to find another IX to get flashed
Old Jan 8, 2008 | 07:41 PM
bigric09's Avatar
lol... well, that is BS... you can go to the dealer worst case and they will fix it, but im almost positive you can use the unlocker to at least get your code out and the init code will be fixed. Also try using an older version of ecuflash, like 1.29
Old Jan 8, 2008 | 07:44 PM
TangoASI's Avatar
hey thanks
basically I should go to the dealer and ask them to clear my ecu?
zbomb's Avatar
MJ's unlocker has always worked for me. I have an ECUTEK that I have flashed over numerous times using the unlocker.
**Edit**Thanks MJ
Old Jan 8, 2008 | 07:48 PM
bigric09's Avatar
Originally Posted by TangoASI
hey thanks
last resort... but it will work. id try the unlocker first ...
open the program, then open ecuflash... do whatever you ahve to do in order to get it to show the menus on the left. None of the options will be available... but, if you scroll down, Mr. immobilizer shows up and the init code should be 0001. Thats how it usually works for me the few times ive had to unlock customer ecu's
Old Jan 8, 2008 | 07:55 PM
TangoASI's Avatar
well I guess I need a cable then lol I drove 3 hours to have some installs and a tune and left only with installs now I need to get a cable and look for a good email tuner I guess
Old Jan 8, 2008 | 08:04 PM
bigric09's Avatar
i know one
Old Jan 8, 2008 | 08:41 PM
TangoASI's Avatar
Originally Posted by bigric09
i know one
let me guess you? hey pm so we can talk
