Boost Problems
Old Feb 2, 2008 | 04:21 PM
EvoAl81's Avatar
Boost Problems
So Last night I was cruising around and gunning it from time to time, when I noticed that my turbo was lagging like crazy. I had the boost set at 20-22 psi. Here's what happens, when gas is applied, the boost would jump to around 12-15 psi and would hang there for a second like it was spooling up, then the boost would kick into around 20 psi. I've never had this problem before intill that night. I was wondering if anyone else had this problem and could shine some light as to what might be going on. Thanks!
PS: Someone suggested that the boost solenoid might be malfunctioning.
(2003 evo: Walbro 255 FP, HKS atmospheric BOV, Apexi AVC-R boost controller, NGK spark plugs, Injen full intake system)
Old Feb 6, 2008 | 08:32 PM
mitsuboost30's Avatar
Well two things... What did u dodifferent tothe car and,, What are u using tomanage boost.. Manual or Electronic.... Either way make sure your stock boost seliniod didnt come loose and or is still plugged in...
Old Jun 26, 2008 | 07:32 AM
slcEvo8's Avatar
Registered User
^^ if every thing is kosh electrically as far as connections go and your car isnt starving for fuel when the boost is lagging try resetting your ecu and go at it again.
