Do I need more fuel to make 400whp?
I want a solid 350-400whp for my DD... not 400whp with meth/alchy but on pump gas. I am assuming I am going to need more than stock fuel. What am I going to need to safely do this?
evoix
300-330whp stock fuel pump will work
330-380whp ( maybe give or take ) 255 walbro fuel pump will be needed
380-400+whp walbro+fuel injectors will be needed, unless ur using alcohol injection which takes off load the stock injectors.
What mods do you have done so far?
If i were you, id get a TBE, a fuel pump, boost controller, and get tuned. That way it will be safe and quick. Then you can always get a meth kit and run it with your stock injectors.
Dont pay too much attention to the whp #'s and the limit of the fuel pump and stock injectors.
Im putting down ~300whp on a mustang dyno with a walbro fuel pump and my stock injectors are maxed out. Go figure.
You first said you want 350-400 on pump gas alone, but now you say you are going to be running water injection?
what's going on here, i don't see any mods listed, it's not just some tune that will get u up to 350-400, you gotta have supporting mods and definately a larger fuel injector and fuel pump, also it's gonna be hard to make that w/ stock turbo although it's been done before. i've got 78cc injectors, walbro 255 fuel pump, intake turboback exhaust, bigger fmic along w/ few more power mods and my goal is somewhere btween 350-400whp just letting u know it takes mods to get that power
