My Evo's Dyno - input needed please!
Old Feb 5, 2008 | 11:47 AM
yellowbirds58's Avatar
Unhappy My Evo's Dyno - input needed please!
KPT6,
Why you no like me?
Old Feb 5, 2008 | 11:58 AM
Mr. Evo IX's Avatar
Verify on a different Dyno or at the dragstrip and if it's really producing that low of numbers then I would perform leakdown and compression test. What gear did they do the Dyno pull in? Have they dyno'd other IX's? What numbers did the other IX's with similar mods make?
Old Feb 5, 2008 | 12:07 PM
KPT6,
Why you no like me?
Old Feb 14, 2008 | 12:37 AM
mr.romero's Avatar
Maybe you had a bad tank of gas.
Old Feb 14, 2008 | 01:38 AM
Jameson_IXMR's Avatar
Good god! Drain your fuel, (or use it) and get some decent fuel. Perform another boost leak check, then perform one on your exhaust. While your at it, mine as well do a compression check. you can get the compression checker then use it to do a boost leak check, with a simple adaptor for your intake. Something is not right there my friend. Best of luck to you.
Old Feb 14, 2008 | 01:52 AM
spdracr's Avatar
definately compression test it and leak down test it.
Old Feb 14, 2008 | 03:43 AM
ONRAILS's Avatar
A good tuner would've known if you had a bad boost leak.
A compression test will do youno good but make you worry. IX's are all wacky from the mivec
Old Feb 14, 2008 | 04:45 AM
tephra's Avatar
what did the evoscan log reveal?
my STOCK ix produced 153kw atw...
MR Turco's Avatar
What did the logs say? Was the car pulling timing, what boost were you hitting?
Old Feb 14, 2008 | 08:39 AM
KPT6,
Why you no like me?
Old Feb 14, 2008 | 08:49 AM
MadMsheen's Avatar
Congrats. What was the problem?
Old Feb 14, 2008 | 08:56 AM
KPT6,
Why you no like me?
Old Feb 19, 2008 | 01:17 PM
undeadmonk's Avatar
check with tuner
Old Feb 19, 2008 | 01:20 PM
Wicked E's Avatar
Why can't you just tell us what the problem was? Might help others in the future who are searching for similar solutions...
Old Feb 19, 2008 | 01:25 PM
Inprogress's Avatar
Also, how different do both dyno's read? I mean the GST dyno could read higher and inflate your numbers, which means something still may be wrong. I sure hope that's not the case and am not trying to instigate anything, just throwing out another possibility. If it's not the case, then congrats on getting everything squared away and making some solid numbers!
