size injectors
Old Feb 17, 2008 | 08:27 PM
evo_man_06's Avatar
size injectors
whats the largest injectors you can use with the ecu +
Old Feb 18, 2008 | 01:02 AM
burgers22's Avatar
Max size avaliable in the software is 780 but you maybe able to go bigger and scale by another method.
MB
Old Feb 18, 2008 | 05:59 AM
evo_man_06's Avatar
darn it
i needed to go with 880cc/min thank you for your time
Old Feb 18, 2008 | 06:14 AM
06ravenmr's Avatar
u r installing the fp green turbo, r u planning on running bigger.780's r plenty for that setup. setup. fyi u can use the 880's on the stock ecu its just a pita to get to idle right
Old Feb 18, 2008 | 08:56 AM
evo_man_06's Avatar
fp green
it'll be a while b4 i get the fp green i have to wait to see how much me and my wife are getting back so we know how much we will both get...but i guess i stick to the 780cc/min injectors then if thats the highest i can go. i plan alot later on buying the 25g turbo kit from greddy. but for know depending on how much i get back on my return fp green is on my list
