afr
Old Mar 14, 2008 | 07:57 AM
eponti's Avatar
afr
My afr at wot is reading 12.2 with 0 knock on a 100 oct.Is that too lean?Not sure if its safe enough to run it at the drag strip
Old Mar 14, 2008 | 10:46 AM
lemmonhead's Avatar
most say 11.2-11.5 gives best results with safety margin. 12.2 is to lean up top i say. You dont have to knock to be causing wear on your engine. But eventually it will be to late and you will start to knock like crazy.
Old Mar 14, 2008 | 11:04 AM
TouringBubble's Avatar
12.2 isn't too bad for 100 oct. I've run 12.0 on 93 before ... 12.0 would probably be safer on unleaded fuel and you'll probably have a little more power potential too.
Old Mar 14, 2008 | 09:17 PM
eponti's Avatar
I will have my tuner adj it a little bit.TY
Old Mar 18, 2008 | 12:52 AM
80210's Avatar
12.2 is the optimal burn rate for gasoline, however with that said, the 100 provides some safety but I agree that you should maybe richen up slightly up top to reduce any harm on you're engine even if you're not experience knock.
Old Mar 18, 2008 | 11:57 AM
philevo's Avatar
retune to get your afr down to 11.5-11.7 to be safe
