HELP!!!!!!! Check Engine Soon light came on!!
Old Mar 15, 2008 | 05:56 PM
jaysonmyfeet07's Avatar
Ok, i so just got my exhaust installed yesterday morning, went to work and back with no problems. But i was just coming from work right now and the CHECK ENGINE SOON light came on!!!
Could it be because there is something wrong because of the exhaust??
Please, i need help!!!!!
Old Mar 15, 2008 | 06:00 PM
Turbo Meg's Avatar
Are you running a cat or test pipe?
ak47po's Avatar
Does your exhuast have a test pipe in place of the cat?If so you need a cel fix it's really cheap.
Old Mar 15, 2008 | 06:03 PM
yea... i removed the cat... this is the exhaust im running:
http://cgi.ebay.com/ebaymotors/Lance...spagenameZWDVW
Old Mar 15, 2008 | 06:06 PM
ak47po's Avatar
You need one of these for the O2 sensor.
Old Mar 15, 2008 | 06:07 PM
Turbo Meg's Avatar
Search exhaust cell fix! This way you can learn what the problem is and how to fix it.
Old Mar 15, 2008 | 06:21 PM
Dipz's Avatar
Holy crap, that's cheap as hell..
Is it giving you any other problems?
Old Mar 15, 2008 | 07:04 PM
NO!!! the exhaust is great!!!! i love it!! but only the engine light came on now..
Old Mar 15, 2008 | 07:09 PM
Jeovannie's Avatar
that's normal if you are not using the catalytic converter
Old Mar 15, 2008 | 11:22 PM
so is there anything i could do so the light would turn off?
Old Mar 15, 2008 | 11:35 PM
Jameson_IXMR's Avatar
What this guy said will turn your light off.
caLi4G63's Avatar
yes, look at the picture above, notice how the O2 sensor is not directly connected to the exhaust, see the the adapter in place? you can purchase one of those from vendors on this forum to fix your problem.
Old Mar 17, 2008 | 10:17 PM
gmore84's Avatar
I just bought the same exhaust today.. is it working good? Find any defects?
Old Mar 18, 2008 | 11:55 AM
philevo's Avatar
buy a cel fix. its an extension that puts the o2 farther from the cat then go to auto zone to remove the code.
Old Mar 19, 2008 | 05:48 PM
no, the exhaust is running great!! youll like it!!!
