Greddy Emanage
Old Apr 20, 2008 | 03:13 AM
Turbodemon's Avatar
Greddy Emanage
Anybody out there using a greddy emanage. if so is it a good capable system for the evo and what mods are you running in the vehicle. the price looks good for the emanage compared to ams motec and other brands but is it worth it over just a reflash????
Old Apr 26, 2008 | 09:56 AM
gtauto's Avatar
Greddy emanage is a piggyback ecu. I has very limited functions. If you have slight mods on your car, you will be able to use but if you change to a larger cc injectors then you will have to go standalone.
Old May 31, 2008 | 01:42 PM
dibsen's Avatar
this statement is incorrect, the emanage has a inj. calc. function any it is one of the things the emanage does well.
All you do is input the existing value then put in the size of the new inj and the emanage calculates the fuel.
Old Jul 25, 2008 | 11:13 PM
boostless's Avatar
Only the E Manage Ultimate or V Manage should be used on the IX. The blue is too limited
Old Aug 8, 2008 | 07:33 PM
hytek369's Avatar
how is this better than AEM or just a simple ECU flash?
Old Aug 21, 2008 | 05:21 AM
fred 62's Avatar
with the ultimate, you can modify airflow, ignition and injection !
you can run targeted injection map, rev limiter up and launch control, big injectors.
you can control boost solenoid, or water injection solenoid valve, or water spray for example. you can also logg a lot of parameters.
not as good as standalone AEM for sure, but it's easy to tune and you can control some systems.
( i use it for a 3000GT with water injection and water spray control )
and it depends of the degree of modification of the engine !
for me, this product as map-ecu2 is a good way for someone who don't want to go to standalone ECU.
it's ok for a 3000GT ecu who can not be remapped, but for an evo i don't know if it is really necessary.
in any case, i like it !
fred
LVLANCER
Lancer Aftermarket Forced Induction Tech
10
Sep 21, 2010 08:29 AM
808EVOLUTION
Oct 10, 2006 05:51 AM
DC2TMike
Nov 4, 2004 06:24 PM
BRKENG
Aug 8, 2004 05:32 PM
xcdan
32
Jun 8, 2003 02:37 AM
