Finalizing map
Old May 3, 2008 | 11:39 AM
eponti's Avatar
Finalizing map
Do you guys normally finalize a map doing a 3rd or 4th pull?My map was finalized on 3rd gear pull but then when i logged doing 4th gear pull it knocked.I'am confused
Old May 12, 2008 | 03:03 PM
recompile's Avatar
Different gears will usually equate to slightly different areas of the fuel & timing maps, and will also give you slightly different AFRs.
It's usually best to setup 3rd gear so it's perfect, and then fine tune other gears as needed.
Old May 14, 2008 | 10:14 AM
RazorLab's Avatar
What shameless said. If tuned with care (and experience) it should be pretty close:
Old May 14, 2008 | 07:29 PM
eponti's Avatar
ok ty
