ROM read & write error.
Old Jun 9, 2008 | 06:39 AM
Malmoe_Sweden's Avatar
Urgent need of ROM help.
After a ROM reset. Battery disabled. I am not able to read my ROM.
Have flashed it numerous of times with no problems what so ever ,but now it wont read or write. Car runs fine but i am about to fine tune it so I need everything to be in order.
The Openport 1.3 cable was still in OBD connector when I disabled the battery but that shouldn´t cause any problems?
What could have happened?
I have tried ECU unlocker with no success.
// Lars
Old Jun 9, 2008 | 08:35 AM
TouringBubble's Avatar
Try to warm up the car for a few minutes before reading the ROM. Sometimes low battery voltage can cause issues.
Old Jun 9, 2008 | 09:36 AM
Could it be the Openport 1.3 cable that causes the problem?
Has it happened before that someone managed to damage it by disconnecting the battery?
Old Jun 9, 2008 | 05:04 PM
evo8426's Avatar
did you warm the car up and then tried it? because ive had the same problem where i cant read or write because and then driving the car around and then trying it worked just fine
Old Jun 10, 2008 | 12:00 AM
I took the car out for a long testdrive with no success.
The ROM still won´t open up.
I have to try my cable on a other car just to make sure.
// Lars
