Logging Funtions With Autronis - wow
Old Jun 15, 2008 | 04:06 AM
Boost Oman's Avatar
Autronics has an amzaing system that can trigger the log automaticly and stop automaticly any parameter can be chosen to log, and the frequency can be set..
the other amazing function is that all this can work in a loop were the old logs will be replaced with the new ones.
so you can set you car to start looging at 3,500RPM (usually thats when things go wronge) and if anything goes wrong you can look back at your log.
this function is also useful if someone takes your car or its at the serivce garage you can find out if anyone drove the car hard!!!
all of this and its easy to set up1!!!
check out the link below,
http://www.mrm-racing.se/forum/showthread.php?t=208
Autronic ur so cool!!!
