Optional boost control help thru ECU
Old Jul 8, 2008 | 02:50 PM
jason r's Avatar
Hi Guys,i have just fitted my Apexi D-jet to the car and all is working ok.I also added the optional boost control solenoid kit and this runs off the main vehicle wiring loom with the cable that came with it. However, i am wondering if it can be wired into the 5 pin boost control plug on th ECU.As it is,3 wires are used by the map sensor and i am guessing that the other two are for the solenoid.
If so,can anyone let me know if they have wired theirs up to the plug and which way the wires go in. Thanks.
Old Jul 10, 2008 | 02:08 AM
paulr33's Avatar
correct 3 wires are the for map sensor
power, ground, signal (dont know what order)
and the 2 other wires are for the solenoid, power, ground
Old Jul 10, 2008 | 01:27 PM
jason r's Avatar
Thanks .Do you know if there is more of a benefit to run the solenoid through this plug,rather than the standard wiring loom.I would of thought so if Apexi have chose to put this in the ECU design.
