mail in flashes?
Old Aug 24, 2008 | 02:51 PM
blackblaze427's Avatar
mail in flashes?
is there anyone else besides dynoflash that does this? i am jw and trying to shop around. thanks guys
Old Aug 24, 2008 | 04:30 PM
joyce1bro's Avatar
mellon FTW
Old Aug 25, 2008 | 11:19 AM
Mellon Racing's Avatar
^^ thanks
blackblaze427 let me know if I can help www.mellontuning.com
Old Aug 27, 2008 | 06:41 PM
thanks guys, tryin to save up some cash right now. ill be in contact as soon asap chris, thanks!
Old Aug 27, 2008 | 07:37 PM
92gsxbaltimore's Avatar
Although I tune myself and have never used his services, I have never heard anything but 100% positive reviews from Mellon. He has been tuning various Mitsu's for quite some time now, and he seems to be very good at communicating what changes he is making throughout the process which is what you would want if someone else is messing with your baby.
Old Aug 28, 2008 | 07:28 AM
thanks Caesar and good points
Old Aug 28, 2008 | 12:17 PM
monchy's Avatar
What if i install cams and cam gears? Remember you have to play with the cam gears to get the right tuning. Does he tell you what to do and how? I never asked Chris about that when i tuned with him
Old Aug 28, 2008 | 12:43 PM
usually I leave it up to the customer to determine the optimum cam gear settings and I simply dial the tune in around that...for the most part a good cam doesn't need cam gears in my opinion
Old Aug 28, 2008 | 12:49 PM
tvbf1's Avatar
Isn't Cam Gears an undesired item for street use because it may slip?
Old Aug 28, 2008 | 02:05 PM
The only time I ever saw a cam gear slip was when a friends timing belt snapped causing piston/valve collision, which in that case made no difference if the cam gear slipped or not because he had to pull the head anyway.
Old Aug 28, 2008 | 06:04 PM
monchy's Avatar
But i heard that to get the most out of your evo8 you need to play with the cam gears and i don't know on what numbers - or + they have to be set up.
Old Aug 28, 2008 | 06:12 PM
what Mellon is saying, is that a well designed cam shaft will be setup to run optimally on our cars "on the keyway"
Old Aug 28, 2008 | 06:31 PM
monchy's Avatar
Old Aug 28, 2008 | 06:34 PM
monchy's Avatar
Well i bought the Comp cams and fidanza cam gears but don't know how good they are.
Old Aug 29, 2008 | 04:52 AM
piotr4net's Avatar
Go with Mellon , It is very helpful man. I personally have very good contact with him, He reply all my stupid newbe question
