HKS 280 Cams?
Old Aug 24, 2008 | 04:14 PM
SooReal's Avatar
HKS 280 Cams?
Is it ok to put HKS 280's while having a stock turbo? and can I run the same springs, retainers and valves.
Old Aug 24, 2008 | 04:16 PM
Evoryder's Avatar
yes and yes.
Make sure you tune once installed.
Old Aug 24, 2008 | 06:30 PM
Oki Panoki's Avatar
yeah. but ive been debating cams myself for a long time. im not so sure i can handle listening to the idle. for a while its cool. and i may be able to get usto the 272's cuz there not to bad. but 280's i dont think i could handle, there pretty lopey
Old Aug 24, 2008 | 06:34 PM
COEVOPOWER's Avatar
Yeah its fine to run them. especially if you get the valve train to support it.
Just get tuned.
Good Luck
Old Aug 24, 2008 | 06:35 PM
griffeyr's Avatar
I wouldn't do 280s w/o upgraded valvetrain...just my 2 cents
Old Aug 24, 2008 | 06:41 PM
SixOneNine's Avatar
I have HKS 264/264 cams for sale. Stock like idle.
Old Aug 24, 2008 | 06:49 PM
STIKILLA1084's Avatar
I would change the springs and retainers and get a tune.just my 2 cents
SixOneNine's Avatar
HKS cams do not have a high lift so stock valvetrain is fine. Stock turbo's are out of its efficiency range above 7500 anyway.
You can play with different cam gears settings to smooth out the idle a bit on 280's. But it'll always be somewhat lopey.
Old Aug 24, 2008 | 06:54 PM
Blue Evo 8's Avatar
I ran hks 280s on my stock 05 turbo set-up.....and made like 380 awhp out of a restrictive 3" catback
Old Aug 25, 2008 | 12:40 AM
SooReal's Avatar
aye guys, I was also wondering if I need to get a upgraded ecu to accommodate it. or can I just run stock ecu?
Old Aug 25, 2008 | 03:54 AM
griffeyr's Avatar
you can run stock. just gota get it flahsed and tuned
tbaird58
Feb 21, 2017 06:13 PM
cvnick
Jun 25, 2015 06:15 AM
4G63 T
Jan 15, 2006 08:30 AM
alex_alex
15
Aug 12, 2005 08:16 AM
gldenchld
Jun 13, 2005 12:22 PM
