Knock in High Boost with Right AFR
Old Dec 5, 2008 | 04:51 AM
gtm_maxwell's Avatar
I come cross some Forum saying that too rich will cause knock?. is that why I got Know for WOT?. but when I try to increase the throttle slow. I GET 1~5 knock. when it reach 5400rpm in 3rd Gear?.
Old Dec 6, 2008 | 02:55 AM
Today I try reduce the Ignition on the 5400 to 5800 RPM and got less than 56 Knock. is that ok or not?as is very close to the Warning 60 knock.. Should I reduce more timing?.
Old Dec 6, 2008 | 06:34 PM
saltydog's Avatar
the problem with the commander is it logs basic max knock. You can get one incident of knock in a cell and this is the figure it records. Are you hearing knock? you need to verify knock using something such as this
http://www.phormula.co.uk/Default.aspx
Regarding timing vs afr I run 12.1 - 12.3 and timing of 16 degrees, but then i also run water meth and our spec is very different.
I would follow some of the advice you got earlier, reduce timing in this area to 6 degrees and check the knock again. make sure your afr's are good and then add timing until you see knock.
BTW it is virtually impossible to tune with the hand controller, you could try datalogit
Old Dec 6, 2008 | 06:38 PM
saltydog's Avatar
I dont get more than 25 knock ever. you need to determine what is acceptable knock for your engine
Old Dec 7, 2008 | 09:10 AM
Yap I am using Datalogit with LS1 wideband.. so do u want to have a look at my map?...I can put in on here and the FUEL and IGN map if u want..
Old Dec 8, 2008 | 03:29 PM
saltydog's Avatar
sure, I also saw your post on the datalogit forum, no problem send me by e-mail or Pm
Old Dec 12, 2008 | 04:00 AM
nianlala's Avatar
I would be happy to have a look at your maps also. You can email me on nianlala@hotmail.com
I have been running my setup for 2 years now, my target AFR is around 12.0 at the top end. I run around 33psi (2.25bar) on 93 pump using a GT35, no meth, no alky. 525whp. My knock counts are under 30 all the time. Ignition advance at around 5800rpm (@1.9bar) is around 12-14. I can email you the IGN table if you are interested in seeing it.
Old Dec 12, 2008 | 04:10 PM
base Map/ Ing Map
here is my base map and Ign Map...
I will attach the Targeted A/F on the next Message
Attached Thumbnails Knock in High Boost with Right AFR-basemap.jpg   Knock in High Boost with Right AFR-ignmap.jpg
Old Dec 12, 2008 | 04:14 PM
Here is my Target A/F
My Targeted A/F
Old Dec 12, 2008 | 04:21 PM
WOW that's great I would love to have a look at the Ing and Fuel Map for reference, Please email the Ing/Fuel Map to gt_maxwell@hotmail.com
I would love to see what is the different..
Old Dec 14, 2008 | 04:29 AM
So any comment about the ign map or the Fuel Map?
Old Dec 15, 2008 | 07:00 AM
saltydog's Avatar
Pm me your DAT file and any recent log files that you might have, this way I can open them with the datalogit.* The ignition and fuel files will mean more if I can check the rest of your settings.* So said that you are using the innovate, are you logging the AFR's throught the datalogit? this is also very useful when tuning.* The log files will also shown me knock in the 4 ways, basic max, basic average, advanced max and advanced average.* You need to figure out if it is real knock or not.
Old Dec 15, 2008 | 07:02 AM
saltydog's Avatar
from the pictures the timing looks at little high, have you looked at the actual timing versus the commanded timing? this can vary for serveral reasons one of which is battery voltage. Send me the logs and I can help
Old Dec 16, 2008 | 12:11 AM
OK I will try to zip the log file first. as someone told me that the log file needed to be zipped if not the file will not work.. so I will try to zipped it, if u can't open it let me know. O and about the actual timing i think is at 10Degree..so my timing is a bit high..ic I thought my timing are too long...^_^ my mistake than...Haha..
Old Dec 16, 2008 | 12:29 AM
Log File
Here are 2 log file for Run3
File Type: zip
