rpm raise neeed help!!!!!!
i need some serious help guys. i posted numerous times but no help at all. everytime i shift my rpms raise up!!! its so annoying. i cant take it anymore. it only does it sometimes i guess more when the heats on. it raises essipiccly when i shift fast....the only answers i got were to clean my throttle body. thats the only thing. what do you mean clean it? take the intercooler piping off and wipe it out??
and someone else said it could be a throottle sensor?? can anyone chime in who has heard of this b4...\
thanks guys!!
and someone else said it could be a throottle sensor?? can anyone chime in who has heard of this b4...\thanks guys!!
Sounds like you have already had a few suggestions you should try. I would inspect your throttle cable for corrosion, and check your throttle plate. Make sure these are both clean. Yes that does mean take your upper intercooler pipe off at the throttle plate and see how easily it moves. I'd say also use your hand with the engine not running and open your throttle where your throttle cable connects to the throttle body. Worse case scenario, I would see if you can rebuild your throttle body, or replace the tps sensor, or go get tuned and see if it helps. Let me know what you find.
