Tuning a stock evo
Tuning a stock evo
This is more of a curiosity question and I tried searching but nothing really came up. Has anyone ever re-flashed a totally stock VIII or IX? Are there significant differences in HP, Torque, MPG, etc? Waste of time and money?
Just curious...
Just curious...
It's absolutely worth it with no mods, but if you would browse/search the forum, you would find that out. My evo (stock, with a boost leak) peaked at 17.5 psi and tapered to 13.5. You can up this quite easily to 22 or more with a bone stock car. Given, doing just an intake and exhaust will do wonders since turbos like to move that air
Without a doubt woth it. Even more so with the addition of a $100 boost controller that can easily be put back to stock. The only problem is that once you start modding you usually only stop when you run out of money
no difference, it was just a question. I would rather deal with someone local that's why. I'm your neighbor by the way, I live in Merrick. I'm sick of getting 16 mpg and hoping to get a better response from my turbo. Once I have the scratch you might be seeing me.
I had the exact same question and started a thread a while ago, got some good feedback:
https://www.evolutionm.net/forums/ev...evo-worth.html
i'd vote for skipping the boost controller and use ecu boost control (not sure you even have to swap the stock pill out for a stock evo). and you are indeed correct that lack of money stops the modding process most of the time haha
